need tranny help
onequicklaser
Oct 1, 2005
martinsburg, West Virginia
yeah i was driving home today and i went to get on it i was in 1st i went to bang 2nd and it was like i missed sounded crazy but i lost 1 and 2 gear and when i got home i still had 3rd and 4th gear, but when i got home i looked at the linkage cables that connect to the tranny the one linkage was popped off the cotter pin flew out or broke, but the problem is now that the tranny makes a horrible noise when the clutch isnt in gauged and if the cars in neutral and you revv it up the tranny makes a noise what can this be? i have another tranny if this ones ####ed and the car also has act 2100 clutch if that means anythign and the car is a 90 laser turbo fwd
You put a new pin in right?
Have you checked to see if there are any cracks in the bell housing? Checked the fluid levels? How many miles does that tranny have on it?
Horrible grinding noises is definately a problem. You could very well have broken a shift fork or worse. If you just had the shifter linkage slip off it would work right when you reattatched it. If that is hooked up and you're still grinding that spare tranny is going to get some work.
yes i replaced the pins and reconnected the linkage......well i dont think its my tranny anymore i think its coming from my motor know that i can see in day light, but the noise seems to be coming from the engine and when i rev it up the stock boost gauge dont read vacuum or anything .......... do u think the motors shot?
