Need to find +12v Line
djXternal
195
Aug 30, 2004
Wesley Chapel, Florida
Hey guys I need to find where the +12v Line from the battery to the alternator runs in the engine bay, I am going to be upgrading this to higher guage wire so I need to figure out where it runs and the best way to access the alternator end of it
Thanks
Shound be dual white wires in a separate harness that run from the alternator straight to the fuse box and bolt in to the main fuses.
Terry
djXternal said:
Can I get to everything from below the car?
Along the back side of the block, yes. At the fuse box, not really. I'd suggest getting under the car and starting the wire up from the alternator. Terminate the connection on the alternator, then feed the line back towards the battery and up where you would like to run it (shortest distance, best appearance, whatev). Then you can finish up the project standing up at the fuse box/battery.
