Need some Engine/turbo help
BlackEclipse62
61
Jan 30, 2005
Madison, Georgia
I installed my exhaust cut out today and I was driving it and it spike to about 13 pounds of boost, and then i pulled back into the muffler shop to pay them the money and when i went in nothing,but when i came out and crunk her up there wasa lot of white smoke coming grom my cut-out and where the turbo meet the downpipe. We checked for blowby they didnt feel anything, so i took the turbo off the header and saw oil in the manifold so i thought bottom rebuild :cry: , but i cranked her with the turbo off and there was no smoke coming from the header, so the guy at the muffler shop said it is probably the oil seal on the turbo. He said take it easy all the way home. So i bolted it up and drove it easy all the way home. Do ya'll have any suggestions of what can be my problem could be. It goes trought oil like crazy now. thanks for ya'll help!
Andy
Well, first things first, compression test, and leak down test will tell u everything you need to know. It will at least tell you if you did anything to your bottom end from that boost spike.
good news guys, i just got through with a compression test and the result were 185-180-185-200, so from the result of this I am asuming that it is the oil seal in the turbo so I guess i will save up and send it off to get rebulit. Would that be the only reason it would just blow white smoke out of the exhaust when the turbo is hooked up? thanks again for ya'll's help.
Andy
Usually white smoke means headgasket, but your compression numbers are okay so I'd say rebuilld the turbo, or depending on the cost of that, look for a BB T3/T04E.
I think i will go the rebuild route, do ya'll have any reccommend shop who rebuilds turbochargers. The cheapest i have found so far is www.turbochargers.com for $275, and Forced Performance is $350. Do any of ya'll know any shop is cheaper? Thanks again for the help!
Andy
I got a summit racing 2 1/2 inch exhaust cut-out. For right now it is just the manual one where you take the plate off, but i hopefully plan on getting electric cut-out ( after i get this turbo rebuilt or a new is bought). It is night right now i will take some pics tomarrow after church. It sounds so nice!, i would drive it right now if it didnt burn so much oil. You feel and hear the turbo spool up quicker! :thumb:
Andy
My exhaust cut-out is black instead of the pretty one you got. I took off my cat and intalled it where the cat went and faced it towards the drivers side of the car. I will post some pics tomarrow of it. Good luck on your install and hopefully not boost spikes! :thumb:
Andy
her are some pictures of the exhaust cutout on the car. You can see where they put it where the cat was at and made some hangers to hang the new pipe on. They are alittle blurry sorry bout that i cant figure out how to use this digital camera right! :mad:
Andy
You can get everything from summit.org, the exhaust dump is like 27 dollars and the electric cut-out is aroung 189 dollars.
Andy
