Th3ory
- 219
- 29
- Aug 6, 2015
Centralia,
Washington
Hello all, I am looking for some advise/suggestions.
When I bought my 98 GSX, I was told that there was an issue with the transmission gasket that caused a leak, which lead to transmission failure. This was many years ago, and the previous owner bought a used 95/96 transmission. They quickly realized that the 95/96 transmission would not bolt up to the t-case. They had to also replace the t-case with a 95/96 t-case to match it up.
Fast forward to the present, I'm now planing on having the transmission rebuilt/upgraded to withstand the extra power the car has (my goal is 400whp). I have started my research on this issue (why and what is the difference in the tranny+t-case in the 95/96 to the 97/98/99). So far I have only found out that there is ONE extra tooth in the 97/98/99 trannys/t-case. Over the 95/96.
So my main questions are; is the 97/98/99 trannys/t-case stronger, are they more efficient? Why is there 1 more tooth?
Should I just rebuilt the 95/96 setup I currently have? There is a local seller close to my location that has a 97 setup for sell off a shell for $600, is it worth the money and time to get the 97 and have that rebuilt/upgraded?
Any advise would great!
