Need help!
RussianEclipse
38
Sep 25, 2012
Walnutport, Pennsylvania
Alright trying to get my car started and wasn't getting power to fuel pump so we did the whole rewire with relay and online fuse then made a switch to turn it off and on and it is working but it is sending to much fuel into the motor, and flooding it. Does anybody have any ideas? Could it be the fuel pressure regulator or is there certain amount of power need to go to the pump?
There's a difference between the rewire and hot wire. You didn't run another power wire to it did you? I would check your fuel pressure with a gauge and see where it's it. Unless your mpi is bad and it's hanging the injectors more open then normal. I would go through it and find out why it stopped working in the first place doing a bypass is only temporary. Which could cause more damage in the long run.
