Need help with vac routing for 1g NT TB on 2GT
j_choate69
Mar 21, 2005
Fort Polk, Louisiana
Don't know how to route the hoses. Keep getting EGR code. It's not the same as the 1g turbo throttle body. Everyone keeps directing me to the rre article for 1gT to 2gT but the TB's aren't the same and it isn't working right hooked up that way. Pls help.
That's because 1g turbo tb has an extra nipple for vaccum hose, you have an extra hose and nowhere to connect it to.
I removed all my emissions like is seen on taboospeed.com but I left all the sensors plugged in and I never get CEL's. Make sure you block off the EGR valve though. I made a block off plate out of a coke can and put the valve back on. Then I made a plate in the mean time out of 3/8 Aluminum. Good luck!
Dude, I trashed the emissions, fabricated the blockplate and plugged it all up. Things are running great, no CEL. Haven't really run it through the paces but I thought I felt a little extra pull. Not sure will have to drive it a little more tomorrow to be sure. Thanks for the great help. I also frequent team-2g.com but you guys are hands down the technical experts.
