2G need help on tires for 98 gsx wheels
NJBoostedDSM
200
Aug 2, 2013
clark, New Jersey
need to replace all my tires, i know the size is 215/50/17 but was wondering if these would fit: Michelin 225/45 R17, 91H, M+S, Pilot Alpin im looking for cheap private selling tires and came upon this good deal looking for some insight on this thanks!
EDIT: found a better deal for size 215/55/17 these should be fine correct?
That will be a taller tire as far as overall diameter. It's okay if you have The space in the wheel wells. Also your speedometer will read a little bit faster than the car is going.
Check out this page with a tire diameter calculator.
http://www.tirediametercalculator.com
what size are you referring to? the 225 size or 215 size?
The 215/55-17. That will be a taller tire.....very small amount, but still taller. You might not notice the difference, but if the car is lowered a lot, it might rub on the bumps and potholes we have here in NJ
