Need help on greddy intercooler install.
Chaddycakes21
225
3
May 28, 2005
Flint, Michigan
Well i just bought a used greddy 24r fmic and i had a few questions on the install. First i wanted to know about the two little black tubes in front of the radiator. These are the power steering cooler tubes right? So my question is..
question 1. Can i just bend these back because they get in the way of my fmic.
Question 2. which bolt hole does the intercooler hook up too? is it the one at the bottom of the hood latch?
Any help is appreciated.
So I was wondering about the same thing. What did you end up doing to make it fit?
Nothing really, all i did was place the intercooler in front of them. I had to move them around a little bit but not much. Only problem with my install is that my passenger side of the fmic is leaning toward the passenger side because the top tube was such a tight fit. I need to move some things areound to get it more straight. It just doesn't seem to want to give anyone have any ideas?
Here's a few pics of my setup with the IC off. The bottom bracket is not straight but when the IC is on it fits perfectly. It helps to have someone standing a few feet away from you when you're moving the IC around. If you need more help on this pm me.
As far as the Power Steering lines go, I ziptied mine. When I took the FMIC off I checked the back of it and the lines did not rub. In case you have problems finding a spot to ziptie....
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
