Need Help Fast!! Possible Tranny !!
redgst95
98
Dec 6, 2004
Mobile, Alabama
My Transmission Went Out Not To Long Ago So I Take The Car To The Local Transmission Shop And I Have It Rebuilt With All New Parts Plus Installed A Act 2100 Clutch & Quaife Lsd,i Get It Back And The Shift In 2nd Grinds A Reverse Is Almost Impossible To Get In! And Coming Out Of Second Into Third At Full Throttle It Would Go Into 3rd Fine Put It Would Redline It Was Like It Was In Nuetral Wtf?!?!?.....so I Took It Back To The Shop And They Said That They Had Put The Wrong "blocker Rings" In So They Bought A Rebuilt Tranny From Mans Trans And Installed It Along With My Clutch And Lsd, Well When I Got It Back Today I Was Checking Out Everything To Make Sure It Was Good This Time...... In Third At Around 60 I Would Give It Full Throttle And It Would Just Redline It Didnt Pull Or Nothing I Had To Ease Off The Gas Then Get Back On It For It To Actually Pull 2nd Does It To Its Like Its Not Grabbing But The Shifting And The Clutch Is Perfect What Could This Be I Was Thinking That It Could Be The Lsd Thats The Only Thing I Can Think If Anybody Can Please Help Me Out That Would Be Awesome Thanks !!!!!!!!!
How long did it take you to capitalize every letter in that post?? LOL
Lots of people have problems with clutch engagement and tranny grinding when installing a heavier clutch plate. They usually end up getting a longer clutch rod. Unfortunately this involves taking off your tranny again. If the problem is in fact with the tranny, then you should take it back to the shop and have them look at it. They should inspect it for free, which means your tranny will come off anyways. If they diagnose it to be fine, then have them put in the new clutch rod.
thats just it i just got it back from the shop tonight for the 3rd time and the said everything was picture perfect i dont understand!! everything feels awesome until i give it full throttle and it feels like i have the clutch to the floor and flooring it! i have to actually let of the gas a little the then give it gas for it to grab!!!could it be the clutch is not adjusted right?!?
Here is a post on the clutch rod:
http://www.dsmtuners.com/forums/showthread.php?t=152430&highlight=act+clutch+engagement
If its a new clutch, then its probably not adjusted right. Do you have fluid in the clutch cylinders? If you don't have enough in there, it might not have enough hydrolic pressure. Just a thought.
I wouldn't think so...that only helps out when the wheels are spinning at different speeds. Check all the fluids and lines to make sure they are all hooked up and not leaking, and if you need it adjusted the place that installed it should be able to do that for you.
