Need help asap..........Transfer case bolt size
Busa_DSM
Nov 24, 2004
Bentonville, Arkansas
Got my parts car home, I was hoping there were transfer case bolts in the back. No suck luck. Can someone please give me that exact number, size and thread specs on the xfer case bolts. I am going to go down the industrial bolt store and see if I can get grade 8 bolts cheaper and faster than the ones from the stealership. IF, this is not a good idea, someone please let me know. Thanks in advance.
Don
The bolts are 12x1.25 pitch. Lucky for you, my xfer case is off. I'll try to measure the bolt sizes tomorrow (if I remember).
Thanx, it will really help
Ok. You have three long ones. They are 12x1.25x130. Two short ones. 12x1.25x70. Each of them has a lock washer on it as well. :thumb:
Thanks bro, going to the industrial bolt shop tomorrow. Going to put grade 6 or grade 8 bolts in it. Everything else might come apart, but those bolts will be good.
