need help 1st gen block in 2nd gen car
NEEDFORSPEED07
Feb 25, 2004
EL PASO, Texas
i have a 2nd gen talon tsi, and i have a 1st gen block i was thinking of swaping them out cause i am thinking of investing money in it and i dont want it to walk i already have the fly wheel. what else do i need to do so i can complete this project thank you:dsm: :laser: :dsm:
what is is the website on magnus motorsports if you know anything else please let me know thank you.:dsm:
ok i saw the kit in magnus motorsports and i have all of that does the 2nd gen head and the 2nd gen tranny fit the 1st gen block thak you dsm.
so i can keep all the stuff that is on the side of the first gen block cause i got it today all cmplete with everything but i havent bought the magnus motorsport kit will it still hook up with out any mounts.
To make a 2g head fit over the thicker 1g head bolts you have to drill the holes in the head bigger. No other mod should be needed and it will work fine. The only other thing you will have to is run a 1g CAS instead of the 2g 2 sensor setup. As for mounts all you need is to cut the 2g mount to fit around the 1g water pump. It is pretty easy let me know if you need more info.
J
I know one guy that did the swap in well under a month, I know another guy it took him over a year. It just depends how often you can work on the car and if you have all the parts and tools needed to do everything.
