1G Need a 4g63t entire engine Exploded view for rebuild.
Ralli-Heart
Mar 27, 2016
Farmville, Virginia
I recently bought a 91' talon as a donor for my 94' 4g37 . The 91' has most of the internals (Block, transmission, Etc.) but almost all of the externals have been parted out before I could save her. I am basically trying to use the exploded engine view to figure out what I'm missing and create a parts list, as I plan to rebuild the 4g63t AWD and do a complete swap into the 94 talon. Any help would be highly appreciated.
Caps or asa should.have what you need. An awd swap in a 1g isn't very likely.
You would be wise to find an awd car. It isn't like the 2g swap. Even the floor pan is different
I have the 91' gsx but the frame is rusted and its missing a lot of the exterior body panels. what about the floor pan keeps the swap from working? What else would stop it from swapping, i know at least that the engine mounts are in the same place.
Not trying to argue, just learn. Thank you for the place to look for the Engine view.
If you look in Asa if I recall the floor pan in a fwd doesn't have a provision for a driveshaft. The gas tank is also in a different location for awd. There is a documented swap from rre if I recall but even they said they would never do it again and that's a pro shop. Awd shells are plentiful now so it's a lot less work to start there.
Any ideas were to look for an Awd Shell?
