Name that connector!
oplix
217
Mar 9, 2008
Zion, Illinois
ok this was mounted under my steering wheel when i bought the car. trying to figure out if this is the standard obd1 connector or something else?
<a href="http://s59.photobucket.com/albums/g313/oplix/?action=view&current=plug.jpg" target="_blank"><img src="http://i59.photobucket.com/albums/g313/oplix/plug.jpg" border="0" alt="Photobucket"></a>
<a href="http://s59.photobucket.com/albums/g313/oplix/?action=view&current=plug2.jpg" target="_blank"><img src="http://i59.photobucket.com/albums/g313/oplix/plug2.jpg" border="0" alt="Photobucket"></a>
i don't think it's obd ii either though...has a strange red light on it.
ive never had experience with it but it could be setup for DSMlink. you can always pull your ECU and check
That is not the diagnostic link connector. It has nothing to do with dsmlink either. Dsmlink plugs into the stock diagnostic link connector.
ok thanks for the suggestions. maybe it does have to do with the alarm system.
its a security chip for a alarm. you plug in the chip to make your car start.
As stated above, it is a security chip for the ignition cut. When you take the chip out you shouldnt be able to start the car. And when you put the chip in you can start your car.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
