my Talons first run at the track
danwheelspin
90
Jun 29, 2002
I couldnt get 13s to save my life.I ran it 4 times,14.7 14.3 14.2 14.2 all of them at 97xxmph,
I think it pretty consestent ,now I know where I stand,and were to improve.
Best time was:
r/t .580
60' 1.9
1/8 9.115 @ 77.33
1/4 14.215 @ 97.04
I wasnt really paying attention from what RPM it was taking of from,right around 4500 to 4800 rpms when I was trying to look,back and forth from the tree and gauge.I might go back next weekend,and use race gas this time,and new plug wires.
with your mods, 13s will be no problem. try to get a lower 60ft time. looks like u should launch higher, atleast 5k.
With a fuel pump rewire and 190pump you should be able to run a bit more boost than 14psi.
I was able to run 17psi just fine (same fuel mods, 16g on a 2g) without knock. If you have a logger slowly turn up the boost and watch knock.
-Dallas J
I was running at 15lbs,I have a datalogger on the way.Going to rewire the fuel pump this weekend.Next time I will try from a higher RPM.I hope I hit 13s before the track closes for the winter.
