My new turbo. Can someone help me find the trim and specs of it.
96eclipseawd
120
Sep 26, 2008
lake butler, Florida
I just bought this turbo from a guy that had it on an ls1 in a mazda miata. He used it for road racing at 7psi. Only has 3k on it.It is a T3 garrett a/r .60-compressor side, and a/r .81-v-band exhaust side. It is oil cooled with a 3" inlet- 2" outlet. Compressor inducer is 2.25" exducer is 3". I've googled this for awhile now and cant find anything. Compressor cover says a/r .60 m24 then it has an L in a box then a sideways B. Can someone help me with the trim, hp and max boost range, type of bearings? thx
How exact are those wheel measurements? There are a few compressor wheels that are in the ballpark, like a 50 trim, 57 trim, 60 trim, and 60-1. Is the comp. wheel 6 or 7 bladed? The hotside sounds like a T04 wheel, possibly a P trim. Are you sure the turbine housing is T3 and not T4? Posting some pics might be helpful as well. Here are some exact measurements of compressor wheels:
50 trim - 2.12"/3"
57 trim - 2.23"/2.95"
60 trim - 2.29"/2.95"
60-1 - 2.32"/3"
Here's a list of current turbos, what you have may be older. The closest thing looks like the 6052E, which is a 60-1 with a 76 trim turbine wheel.
Precision Turbo & Engine - Turbocharger, Intercooler, Fuel Injector, Performance Parts & more!
http://www.extremepsi.com/store/customer/product.php?productid=21036&cat=508&page=1
To calculate trim of a compressor wheel use this equation: TRIM = (Inducer / Exducer)^2 X 100
(2.25/3.00) = .75
.75 x .75 = .5625
.5625 x 100 = 56.25 Trim
That is if your measurements are correct like stated above.
The exact measurement is 2.32"/3" compressor wheel. so it's a 60-1 trim compressor wheel, and an 76 trim exhaust wheel? The turbo looks exactly like the one in the precision link above, it has 7 fins, and the little bit of white paint on one of the fins. Ill load a bunch of pics later today.
It has a t3 flange, and vband outlet. What rpm would I be looking at with full boost? Im trying to get 500hp to the ground. The engine will be built, and probably .40 over w/ 280s, fmic and a 63mm throttlebody. Would it help if i stroked the motor to a 2.3l to spool it up?
In that hotside, with the antiquated 60-1 compressor wheel, full boost would probably be somewhere in the ballpark of 5500+. Fully choked out on race gas you can probably crack 500whp but you'll be working hard for it. There are literally dozens of turbos out there that'd spool 1000 rpms faster while making more power. If you're looking for bang for the buck, take a look at a Borg Warner S360 non-extended tip. You can put it in a bolt-on hotside or a .70 T3.
