my blinkers arent working???? i need help
kris_stewart10
398
Jul 16, 2008
Picayune, Mississippi
okay as the title states i need help with my blinkers i have checked all of the fuses and bulbs but still no work i need help
what could it be????????????
my hazards work just fine
please help
Yes. Power runs through the hazard switch. If it is not making contact inside that switch they won't work when the switch is off, but will flash normally when the hazard switch is functioning like it should.
I took my switch apart and found a broken tab and spring. My hazard switch would also jam and finally got stuck. I said screw it and ordered a new hazard switch for $5! from thedsmgraveyard.com So you really can't go wrong, otherwise you can pull the lower kick panel, trace the wiring from the turn signal switch down to the connector and test pins for continuity in different switch positions.
G' Luck:thumb:
well it clicks down it just doesnt stay down you get what i am saying?????
Well thanks i really appreciate it
i hope that isnt it but i mean i have a few other dsms i can get it off of i have a 90 laser that i can get it off of
