Multiple logs, odd fuel trims
fst_4g63
67
Jun 6, 2006
Saint louis, Missouri
Well here are my logs and situation, The vehicle 92 tsi awd problems are as follows.
Fuel trims with no movement
My o2 is cycling but to no effect, And I also have the proper temperature readings. I am confused to the point of wanting to sell the car, I turn up the boost car acts bogged then takes off. All help will be appreciated and explored fully thank you.
Yeah thats mmcd for yah it labels backwards for no good reason. :ohdamn:
Car does not blow any smoke at all, Currently blowing thru full stock exhaust with 2.5inch dp. The exhaust cut-out motor broke again. I will pull them right now and have a fully positive update I will be right back momentarily.
Well I pulled the all 4 and they are pail white, the armature is actually turning white.
The coolant temps are around 199-209, the airtemps move between 92 and 103, and the bp. is 13.9-14.1 but never moving from there. Like I said thanks again And I will respond immediatley.
For the logger I use outside of link (scanmaster), it should read 100 for sealevel and a percentage lower for however high you are. Saint Louis should not read so low barometrically if that number corresponds to my logger.
This would explain the very lean condition your plugs are showing you. And, would explain the stumble early in the fuel curve.
People continue to think this means it's lean when what may be going on is two things. First is that the car operates in closed loop much of the time and it's going to run about 14.7:1 and second the stock plugs seem to be run at the high end of their heat range which burns off most of the deposits.
6's in my car have been matte white when I pull them normally for almost it's entire life.
Unless you shutdown at the end of a pull and remove the plugs it's hard to get an accurate read by color.
Wondering myself if the massive amount of timing is what is causing the plugs to look the way they do. Which in that case wouldnt I just tell the thing dump fuel and crank the boost (thats a joke) let me know what kind of other things i need to look into.
Well so I changed out the chips back to a stocker. The timing has gone insane at idle without a load, at 750rpm's 6-10 degrees but at 1500rpm's about 35-40. The fuel trims have flipped to the opposite end, while trying to tune now the low end is around 104 pretty solidly. You can actually here the car popping through the stock exhaust, I am thinking about just sucking it up and getting link.
thanks Darren
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
