Talon ESI-T
- 415
- 20
- Nov 11, 2003
Joliet,
Illinois
For anyone who has installed a wideband on their factory controlled motor (before they ran MS or 8inj setup), you have ###### noticed that when you take your foot off the gas the AFR goes to complete lean until you press the gas again. This saves fuel.
After installing the MS you ###### noticed the EGO correction tries to add fuel when you decel. This wastes fuel and doesnt make much sense. I found the fix!
The MS program only sees decel for 2 ms when you let off the pedal. After that 2ms the MS ECU considers the "0" TPS signal to be a condition it calls "Over-Run". To make the MS ECU cut all fuel while you are completely off the pedal you need to alter the OVER-RUN settings in Megatune.
I have yet to play with this but here are some starting settings
Drop down menu "General", click Over-Run Settings
TPS Lower Than enter value of 5
coolant greater than enter value of 160 or 170
After (sec) enter value of 2 or 3
Try that if you have time and let me know what your results are.
Terry
Terry
