motor mounts
2gtuner8
Jan 16, 2007
sinking spring, Pennsylvania
i was wondering where i could find bolts for my front motor mount. after replacing the engine the bolt got lost now the engine has too much movement in it any tips or suggestions?? thanks
1996 mitsubishi eclipse gs:dsm:
Yeah... and most of the time here at my local U Pull It... I can get bolts for free most of the time... if you just go in for a single bolt... I highly doubt they will charge you for it.
if you can get one at a local U-pull it. The front motor mount for mine(GS-T so it might be a little different) was amazingly cheap. So if it is kinda old you can just get a new one and save you some time down the road when it DOES wear out
I just did that mod yesterday and will get to test it out tomorrow when I finally get to drive my car :) I hear good things about it though and from the looks of it, it will work out well.
The bolt and washers were a few bucks like the link says from my local hardware store.
You can use any Grade 8+ fasteners that will fit as a replacement, though I would recommend performing said modification.
