moon roof drain
just5_0
72
Feb 8, 2013
rogersville, Tennessee
How do i go about cleaning the rear drain tube's on the moon roof? The ones at the hatch. I can't get to them from the top the moon roof is in the way i have water behind the passenger and a lil at the driver's side. Thank's
If it's anything like my Prelude, if you take out the interior panels in the hatch, you should see where the drain tubes exit in to the rear wheel wells. The clog is more than likely at the end of the tube. You may need to make the tip a little better to help prevent future blockages.
Air compressor with a soft tip "blow tip" on it I've done this a couple times and worked pretty good, just blows whatever nasty stuff is in there right out:hellyeah:
