Misfiring problem?
JayRolla
5,629
34
Feb 23, 2006
Colorado Spring, Colorado
Ok whats happening to my car is wierd. Most of the time it runs great but sometimes ill be cruising and all of a sudden it starts to bog like its misfiring. If im in neutral and let the rpm's drop it causes my car to stall. If im in neutral at a light it will bog and the cel comes on but as soon as i rev the motor it goes away. It only happens about once a week. When ever it happens all I have to do is hit the gas a little and it goes away. I used palm o stein to read the codes and a bad crank angle sensor pops up. If I use MMCD it has no codes. Could the crank angle sensor cause this to happen?
Yes, I believe the crank angle sensor could cause this. If the sensor isn't reading anything, then it wouldn't know what's going on and it'd just crap out and die. Maybe try a new sensor. You have a 91, so a new cam sensor would probably do the ticket. They're relatively cheap and very easy to install. Maybe check the wiring first for shorts and such.
So since im a 91 your saying I dont have a Crank angle sensor just the cam angle sensor. Im confused because the ecu code says crank angle sensor not cam angle sensor. Do I have both or just the cam angle sensor?
The cam angle sensor reads the cam angle and crank angle. It's one sensor that does 2 things. On 95-96 cars, they have two different sensors. My point is, it is that sensor which is probably faulty and new ones are usually like 20-40 bucks to get from someone. Search the classifieds or ebay.
