Metal coolant line replacement
Xtreme Legion
94
Apr 18, 2011
Springfield, Massachusetts
Dressing my engine where can I get new coolant lines... The metal ones that bend around front of the engine.
Can I run straight silicone all the way around?
Sent from my HTC Glacier using Tapatalk
I am not sure what pipe you are talking about on the 420a engine but if you mean a radiator hose you can use silicone. If you are talking about the one one like on the 4g63 engine that runs along side the block your best bet is to just take it off and bead blast it, paint/powdercoat and be done.
Its the metal lines that run along block. They are pretty rusted. They are the lines that feed back towards the heater core
Any type of silicone/coolant hose will be sufficient. Avoid any contact between the hoses and the block and it also might not be a bad idea to replace any clamps with new.
