May have ordered wrong flywheel. How to check flywheel?
Valenzuela dsm
30
15
Apr 6, 2023
Big spring, Texas
Now I think I'm going to have to replace the fly wheel I think I got a AWD fly wheel not pay attention would I need to pull the engine out or is there a easierway
I believe so need to know if it easier to pull engine or try from the bottom
What the easiest way to replace flywheel
Can I do that from the bottom or pull the engine
Yes I drop the transmission out the bottom and slide it out the passenger wheel well area. I use an engine hoist from the top but you could use a transmission jack or a regular jack.
Anytime I pull the transmission or motor I have my dad lend a hand as is it’s much easier with 2 people and less likely to damage the input shaft.
You just need to remove the transmission and remove the clutch assembly.
Awd flywheel is smaller in diameter overall but the presssue plate and clutch disc is the same between awd and fwd.
-Daniel
