How to remove Flywheel Studs\Pins
brodiedehass
208
7
Sep 21, 2005
Millersburg, Ohio
I am in the process of having my flywheel machined for a my clutch job and I cant get the three pins/studs out of my flywheel. I have already broke one off. Does anyone now a trick to get them out and where I can find a new one? Thanks
Well, the machine shop has a puller and will pull them before machining the flywheel. I can't imagine a machine shop without a stud puller. If you broke one, you are going to pay a little extra for them to drill it out and then buy a new one.
Let them pull the others.
Good Luck
Good Luck
Thanks for the advice. On my last clutch job the machine shop didn't have a puller but I found one that does today. Thanks
