major clutch problems
rkn527
64
May 9, 2004
capitol heights, Maryland
i have a 95 tsi awd and i recently pulled the car down due to a leak in the smim and a bad drive side hub to make a long story short i put everything back together and the clutch grabs a little bit and the car will rev high when i hit the gas the tranny is in mint condition i changed the following
throw out bearing,pivot ball,fork,clutch and line.
You're gonna have to put a little more effort into your post if you want a decent response, it's confusing. You just "pulled the car down" and replaced the clutch, line, throw-out bearing etc.? Or you replaced it a while back? Either way it sounds like it's slipping bad, it's worn out or oil has gotten on it (rear main seal could be leaking).
sorry for the last post the clutch line,clutch,tob was all changed a while back but i just noticed that when i launch the car on the back wheels spin
