Lowering Springs?coil Overs
91 white tsi
229
May 21, 2004
Springfield, Virginia
I tried to research and didnt find exactly what i wanted to know. I know that suspension can help your 60ft and overall ET if you get the right stuff. I was looking on EBAY :| at coil overs to see pricing. I know with mustangs coil overs in the rear with adjustable control arms and fine tuned = hanging the front wheels out a good while off the line. I was wondering if there is a special style for the AWDs to either make the weight stay on all 4 wheels or if it will allow you to pull wheels. I have seen a few AWDs hang the front up for a good 30 feet. Also when you do lower it with the best for drag racing do you need or can you get control arms or the equal to's. and are there caster/camber plates as on mustnags to help get it aligned? What companys have most of you gone with and what is the ride quility like?
Not sure if this will answer but i will go with coilovers because its like springs but you could adjust with coilovers. Not sure if coilovers will give you good time on 60ft. But i said coilovers is because you could adjust it. Just incase you go some where there is alot of pot holes and you dont want to mess up your car and you could set the ride height just incase you want to go to tracks. I know Tein's is a good company also Skunk2 coilover is good i heard.
Hope i helped little bit... I know i could be wrong about this but i know there is other dsm member will help you out, also i would like to know if i'm wrong..
Thanks
  • Wanted 6 bolt NT water pipe
    • chrisman287
