quest49s
- 111
- 0
- Sep 22, 2002
Austin,
Texas
Here is a little background, I was cruising to work going 40 in 3rd so around 3.5k rpm and car ran great. Car Pulled strong and had plenty of power until, I Pulled up to a stop light and took it out of gear and it died, then i tried to turn it over and it wouldn't start. towed it home last night, I checked everything (spark, fuel, ecu, msd, CAS, ...) figuring that there is no way the compression could have gone straight down the toilet so fast.
I did a comp. test last summer ('03) and the numbers were dry ~160 (+- 5) across the board at 5k feet above sea level, have since put about 4k on the rebuilt motor (then brandnew ~100mi) and here are the numbers from tonight:
cyl 1 2 3 4
dry 75 75 75 75
wet 100 110 110 95
This is very odd to me because the rings just don't all go bad at the exact same time and have the same compression in every cylinder. I also let the car warm up fully before I drove it to avoid piston slap w/ JE's
My timing is dead on so I wouldn't think i smashed the valve train, and also didn't hear any uneasy noises while driving before the episode.
A head gasket probably isn't to blame either as the comp. would likely be different per cylinder.
I wouldn't think it to be any sort of crank walk cause it's a six bolt but I never had any of the symptoms that a crankwalking 7 bolt would have.
Does anyone have any clues as to what is up?
Motor Stats:
'91 6 bolt w/ 4k mi
Rebuilt last winter w/ the following:
JE 9:1 pistons ceramic coated & teflon skirted
Eagle rods w/ arp hardware
Stock crank
balance shafts removed
new front case and oil pump
Mitsu 4 layer head gasket
Arp Main studs
ARP head studs
bone stock head
ACT 2600 lbs
RRE flywheel
Thanks,
Jon Hebbeln
cyl 1 2 3 4
dry 75 75 75 75
wet 100 110 110 95
Motor Stats:
'91 6 bolt w/ 4k mi
Stock crank
Arp Main studs
ARP head studs
bone stock head
ACT 2600 lbs
RRE flywheel
Thanks,
Jon Hebbeln
I'm on my third engine rebuild with the same numbers as him! I had the block taken to the machine shop, ring gaps checked, crank checked, everything that I possibly could Fk up I let them do. Now this weekend I'm putting a reman cylinderhead on from national cylinder head. I'm praying this works!
Let me know how things work out Jon!
