Log : EvoIII 16g / No fuel
DSMvroom
632
4
Aug 8, 2004
Issaquah, Washington
Mods are in the profile, but basically it's stock fuel. The evoIII is set to 13psi, which it reaches by just after 3kRPM, and begins to creep usually at just around 4kRPM
I wanted to do this log so I can more definitively learn what has changed. I posted so that people can add comments if they wish, and also as a resource for those who are doing homework for things to come.
The pocketlogger samples 15-16/s and I would have left out airflow to increase the data in the other fields but I felt that what was collected was sufficient anyway. Plus, I was curious to see how much air was being pushed.
Some things to note:
1) The car is way too lean, as noted by the timing being retarded ~4700rpm as well of course by the o2 readings.
Note how BAD it is in the upper RPM range when the turbo has crept up to ~19psi. In fact, the o2 is pretty bad all accross the board.
2) Timing only peaks at 15 degrees (Again a sign of being way too lean). If you find my first log I posted, It was on the t25 and timing was up to 22 degrees IIRC @ redline and also .96v
3) 31lbs/min at ~19psi! I am really excited about this because I am just anticipating the future when my fuel is taken care of.
4) I haven't done any WOT pulls with the car since the new turbo, short of getting some logs, and now that I have a few to view when necessary, I think I'll save my new MLS and myself the headache and stay off the floormat for now.
Sidenote: I really should have started the pull at a lower RPM but I was on the highway and despite there being a decent amount of traffic, it was also moving fairly quickly so slowing down to ~3k was not permissible.
And the log . . .
<table x:str border=0 cellpadding=0 cellspacing=0 width=448 style='border-collapse:
collapse;table-layout:fixed;width:336pt'>
<col width=64 span=7 style='width:48pt'>
<tr height=17 style='height:12.75pt'>
<td height=17 width=64 style='height:12.75pt;width:48pt'>Time</td>
<td width=64 style='width:48pt'>RPM</td>
<td width=64 style='width:48pt'>Timing</td>
<td width=64 style='width:48pt'>Airflow</td>
<td width=64 style='width:48pt'>TPS</td>
<td width=64 style='width:48pt'>o2 1</td>
<td width=64 style='width:48pt'>o2 Trim1</td>
</tr>
<td height=17 class=xl24 align=right width=64 style='height:12.75pt;
width:48pt' x:num>5.65</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>3863</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>31</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>3.83</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>16.5</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>0.82</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>-1.56</td>
</tr>
width:48pt' x:num>5.98</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>3883</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>4.6</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>22.79</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>0.18</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>-2.34</td>
</tr>
width:48pt' x:num>6.32</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>3980</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>26</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>9.63</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>100.2</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>0.92</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>0</td>
</tr>
width:48pt' x:num>6.65</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>4098</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>12</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>15.3</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>0.94</td>
</tr>
width:48pt' x:num>6.98</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>4227</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>8</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>18.11</td>
</tr>
width:48pt' x:num>7.32</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>4348</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>9</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>18.48</td>
</tr>
width:48pt' x:num>7.65</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>4469</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>19.4</td>
</tr>
width:48pt' x:num>7.98</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>4586</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>20.39</td>
</tr>
width:48pt' x:num>8.32</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>4715</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>21.05</td>
</tr>
width:48pt' x:num>8.65</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>4820</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>21.89</td>
</tr>
width:48pt' x:num>8.98</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>4953</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>22.7</td>
</tr>
width:48pt' x:num>9.32</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>5063</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>10</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>23.61</td>
</tr>
width:48pt' x:num>9.65</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>5211</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>24.57</td>
</tr>
width:48pt' x:num>9.98</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>5344</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>11</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>25.78</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>99.41</td>
</tr>
width:48pt' x:num>10.32</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>5477</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>26.52</td>
</tr>
width:48pt' x:num>10.65</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>5625</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>27.07</td>
</tr>
width:48pt' x:num>10.98</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>5746</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>13</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>27.87</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>0.9</td>
</tr>
width:48pt' x:num>11.32</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>5883</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>14</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>28.39</td>
</tr>
width:48pt' x:num>11.65</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>6008</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>29.02</td>
</tr>
width:48pt' x:num>11.98</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>6148</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>15</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>29.54</td>
</tr>
width:48pt' x:num>12.32</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>6270</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>29.8</td>
</tr>
width:48pt' x:num>12.65</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>6395</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>30.23</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>0.88</td>
</tr>
width:48pt' x:num>12.98</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>6504</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>30.53</td>
</tr>
width:48pt' x:num>13.32</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>6609</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>31.33</td>
</tr>
width:48pt' x:num>13.65</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>5867</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>3.92</td>
<td class=xl24 align=right width=64 style='width:48pt' x:num>0.72</td>
</tr>
</table>
I dunno why the table is so far down; I can't seem to fix it.
New logs to come when I get more fuel . . . .
The creep is kicking your butt and I agree that the airflow numbers look good for the boost level. I'd either start porting the crap out of that thing or invest in some fuel mods so that you can run it at 19-20 psi safely since that's where it's creeping to.
But then again, you already know that.
