LC-1 Wideband question.
welfle18
474
Sep 14, 2006
Norwalk, Ohio
I want to know if anyone is running this how well it works with dsmlink. I found one for a good deal but cant really find all that much on the forum about it. Thanks.
Does anyone have experience running this particular wideband with dsmlink? I need one but want to make sure the one I get will work with Link!
The LC-1 is fully compatible with DSM Link if you can get it to work. Lots of people have used it successfully and others, not so much. The issues are with the LC-1 itself, not DSM Link. I replaced my LC-1 last night with an AEM digital wideband gauge because I was tired of fighting with it and needed something that would work, and work now. How much are you offering for an LC-1? :)
I run an LC-1 with dsmlink. I have never had a problem with it. I also use the LC-1 to simulate the narrow band signal. I don't know how it would work long term because one of my calipers decided to seize up on me. When the car was it working order I could log front O2 and wideband through egr input. I have never used another wideband so I don't know if there is a better one out there but the LC-1 is dsmlink compatible.
Well I was looking through the captured values section of dsmlink and could find the aem and the plx but not the innovate lc1. I have read different post about problems with the lc1 but wanted to know from people running it here.
LC-1 will work with any EMS no problem. You can program it to output whatever linar voltage output you want. It also won the wideband shootout by alot. I would say it it one of the more accurate widebands on the market. If you cant get it to work with all the support online than you have other problems.
