Laundry list of Problems
PhatEclipseGST
44
Mar 15, 2005
ADAMS, Massachusetts
For starters my aftermarket and stock alarms are acting up. They seem to be on at all times... I had to cut the horn line on the aftermarket but the stock alarm keeps my lights on.. This all started when my friend hooked my battery up backwards. Ever since then ive had some problems. Also my keyless entry remote doesnt work nor do my power doorlocks. Also my turbo timer hasn't been working since then either. I most likely fried that. It still turns on but when i turn off the car it times down but my car turns off.
Definatly check all fuses on your stuff. And if you dont do it already, any time you but somthing electrical in go ahead and throw a inline fuse on there. Also I know some Dodge alarms have a reset inside if you open the factory box up.
I checked the fusebox inside the car and all fuses are fine... Even if I pull the fuse for the alarm it still does the same thing. The fuses in the engine compartment seemed to be fine.
