Resolved Laser rear brake caliper troubles??
hippy
322
Jan 18, 2004
chtown,
Ok my back calipers on my 91 laser rst are seized so i order new ones but im having troubles getting the back ones off?? I took the bottom caliper bolt out and i cant get the top one out its like i cant fit a small enough socket in there to turn the head of the bolt. How do you guys get the top bolt out?? Thanks i had a take teh caliper bracket bolts out in order to get it of but still got a get it of the calpier bracket so how do i do this?? Thanks!
The top bolt doesn't come out. The caliper just slides over it. Unhook the E- Brake cable and unbolt it from the caliper the nut is on the bottom. Then you can swing the caliper up and slide it off it's holder. i just did this on my 90 Laser RS. Oops sorry I didn't see the date this was posted. It just came up when I was posting a new thread. I figured I'd help....not much help 2 yrs later.
