JMFabrications SMIM
Very reasonably priced and local! Here are pics of what it looks like on my 2g. He has also prouced many 1g versions of this product also to which there are proven dyno numbers and track times.
The quality of welds is amazing and can be purchased for $450 ($475 to add the MAP port). This also adds *bling* under my hood to go with my SS Heat Shield and Oil Catch Can (also made by JMFabrications). This product can be purchased here:
JMFabrications 2g Sheet Metal Intake Manifold
Side Note: If you are going to go with the SMIM w/ the 1g throttle body you will need to modify that throttle body. A full write up can be found here:
Throttle Body Swap 2G Eclipse Turbo 4G63 to 1G Eclipse Turbo 4G63 (Courtesy of RRE)
-- You will also need to mod/relocate your coilpack:
2g Coilpack Relocation
