j1g lsd auto
ovk2k5
61
Apr 30, 2009
Spring Hill, Florida
so my shell I bought was, at one time, an auto :banghead: which means now I need to pull out the rear diff and swap in one from a manual because of something with different gears in each. Well I was trying to take everything off, but these bolts are so freaking stuck I couldn't even loosen one, so I'm typing this while I let the wd40 try to soak in a little. Anyway, I noticed my diff says J1G LSD. Is that like a different than normal lsd or just the regular model or whatever? Now I'm just making sure before I go through the hassle of pulling this all apart, I def need to swap it out correct? and my axles are 3 bolt, so I just need to make sure I get a 3 bolt manual. Also, as far as since I have an LSD, if for some reason I can't find an lsd rear diff, will these axles still work in it?
ok thanks, so I guess I'm on the lookout for a 5spd LSD so I can keep my axles, or a 5spd non LSD with 3 bolt axles.
