Is the Treadstone turbo kit legitimate?
Looks good to me, HRC and Treadstone are the most recommended kits for our motors unless you want to piece it together yourself.
ok, so would you guys recommend this one over the HRC one? Because I hear a lot of good things about the hrc one from one of my buddies
Its going to boil down to whether you want to do the searching on how to install the fuel system (weather its ms or fmu, sfmu, ect) and weld a flex section to the end of the dump tube (it will fit with stock the fans, trust me on this one), or buy Hahn's turbo system with instructions and everything you need to get you started. Both are great kits, one has a better price.
hahn is a great complete bolt on kit, but many people end up replacing the fuel system parts (i.e. their regulator and inline fuel pump) with a fmu or vortech sfmu or MSnS or even the Portfueler and they replace the inline pump with an intank walbro.
Figuring out your own basic fuel system is not really hard, a fmu and a walbro fuel pump should take about 1 hr to install and you're good to go for about 7-8psi
Edit: IDK if the treadstone kit still comes with the below intercooler, but I've seen some install pics of it and it looks kinda crappy. I'm also pretty sure you've still gotta fab up your own intercooler piping.
edit again: IMO if you use name brand parts the only way you can go cheaper than the treadstone kit is with used parts, it really is a good deal
