is my turbo toast??
orzech
91
Aug 23, 2004
Honeoye, New York
so i have a big 16g, FMIC, fuel upgrades and shit...
when i boost hard it smokes like a bi***, the rear of my b umper turns black from all the smoke settling on it and stuff. And when i let off the throttle from going WOT, i get an even thicker cloud of smoke. There is a little ammount of shaft play in the turbine wheel. I can boost to liek 13 psi but thats it, i tried turning up the boost but it doesnt work, idk if its my MBC or my turbo. ANy advice or tips would be great.
I also just rebuilt my 6 bolt block somewhat too. new bearings, new piston rings, ARP head studs, and cometic head gasket. i dont seem to have any major leaks, but i havent done a compression test yet though.
Im pissed b/c my car is running super slow, and super smokey for all the mods i have. It is pulling like a mid 14's s 1/4 mile car when i should be able to break into the 12's. I am tuning with DSMlink too. THanks.
Chris
well if the smoke is white then its fuel prob but if smoke is black its oil and since u got new motor im thinkin turbo is shot but i would do compression test frist to make sure.i got same prob but its fuel.
You're a little off on your info :)
Black smoke is fuel, bluish smoke is oil and white smoke is water(coolant).
:thumb:
If the seal in the turbo is bad, it will only smoke under boost and burn oil. My old laser would burn at least 2 quarts a week if I drove under boost often.
  • Wanted 6 bolt NT water pipe
    • chrisman287
