interior lights only work in acc position
PlanZero
1,516
267
Aug 13, 2013
Easton, Pennsylvania
My interior lights, door open light and door chime only work when the let is in accessory position, or start. Also, the radio defaults back to demo mode every time I turn the car on. The original wiring is unmolested, except for the factory radio harness being clipped. I checked all fuses. Is there a possibility that the ecu is resetting every time I turn the car on? I can't pass emissions because my o2 sensors, evap, egr, etc. Aren't ready, even though I've driven over 100 miles since I last disconnected the battery.
On my '91 I put a data logger to it and my ecu was resetting every time i shut the car off, no codes ever. A year or so later ecu crapped out. I did not have any of these issues anytime at all, but I would imagine it depends where the failure is?. Kind of sounds like a wiring issue. I would log of some sort to rule out ecu. And check wiring/grounds, any splices in that radio circuit. Are you pulling any codes? Kind of sounds like the circuit was wired to acc, no constant power
  • Wanted 6 bolt NT water pipe
    • chrisman287
