interior fiberglass question
hewhoisknot
743
4
Sep 21, 2003
Flushing, New York
ok i havea question... when u go to fiber glass the interior... do u just fiber glass over the top visible portions of the pieces or the whole thing... cause if u fiber glass the little tabs won't they be stiff now and now click into place and stuff.... and the leather looking crap on the 1g.... should i pull that off to fiberglass it... cause if i do it'll loose shape and i won't be able to get it back in shap nad in place to mount it... thanx guys... :thumb:
the glass will not stick to the vinyl you have to remove it.
as far as the door handle goes i dont believe you can glass it ur kinda stuck thier. i never used vinly dye so i cant help you out there.
Edit: you should start off with these:
Bondo-Glass Filler
Fiberglass Jelly
Fiberglass Resin
Lightweight Body Fill
Fiberglass Cloth
on the vinyl peices, you will need to rip off the vinyl and padding. Then glass like normal over the frame.
If you want to fiberglass over a plastic peice, then just clean it really well and glass normally over it.
You dont need to fiberglass the clips and stuff, only the parts that show. Be sure to test fit it before you prime and paint it. That way you will be able to cover any areas that arent covered or grind any excess off.
Ok Guys, Do to Lack of Money and Lack of Wife for the next week or so and I have a 40$ Gift Card to homedepot I want to do this project.
I want to lose the grain on all the plastic pieces and prep for paint.
MY PREP SKILLs SUCK!!! i cant do it worth a damn. Any tips?
and i know. (Sand,Sand,Sand,Sand,Sand,Sand,Sand,Sand......you think your done, Then, Sand, Sand, Sand)
I want to do a Pewter/silver type of deal yet i want it thick, durable, and show worthy. Is Gel coat paint the way to go or do i have to have it pulled and sprayed at auto body place?
Help me out guys, lets make a show car :)
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
