installing new aftermarket projector headlights
95 eclipse gs
Dec 13, 2011
cheraw, South Carolina
i have a 95 gs eclipse, i recently just purchased a set of black jdm projector headlights, now here is my prob. my stock lights have a plug coming off each headlight bulb dim and bright. the new headlights have both headlight wires running into 1 plug, now you can see this will not work. also my stock bulb sizes are 2005 and 2006 i believe and the new set has h1 or h11s not sure its the smaller bulbs so i cant just use my stock wiring harness so what do i do. the halo not so much worried they will be hooked into my park lights. thank in advanced
would like to note on each bulb thier is a positive wire coming off the center of the bulb and and negative wire off the house of each and it looks like the two negative wires join half way up the harness to make one wire. so it turns into a three wire plug.
ok im retarded,LOL but under the stock headlight their is a plug that is used to join the wires for the high and low bulbs together just like the aftermarket so its plug and play
Yeah I guess the stock wires come off the bulb then link in the housing somewhere but yeah idiot moment the new set with h1 bulbs would have been a easy modify if I had to
got another question, now with the bulb change how do i order a hid kit do i just search for H1 hid kit or something else i just want the wiring to match up or search for 95 eclipse H1 hid kit
