installing fuel pump trouble
dboyle23
297
16
Jun 10, 2010
Chicago, Illinois
I cannot remove the feed line from under the car to remove the fuel pump. Is there any way around it? Can I just cut it off and use some rubber fuel line or a fuel line kit or something?
I have tried using a crap ton of pb blaster, but to no avail. Should I try the one on top of the fuel pump?
I wouldnt cut it. just get some bad ass vise grips for the small fitting na d a wrench for the larger one and you should be good to go. Just make sure you turn in the right direction.
If you can't get it off you can use fuel line...I couldn't get mine off my TSI and had to go to napa and buy rubber fuel line and run it.
Sent from my Ally using Tapatalk
