bastarddsm
- 5,774
- 1,703
- Aug 26, 2003
Mendota,
Illinois
Recently I built a new harness for my car, and have some extra stuff left over. All of these are quality oem supplier pieces, no Chinese eBay junk.
First up, a set of injector connectors these have a wire lock just like the original 1g connectors do, and are somewhat hard to take off, but they will stay on though. $20 shipped.
Next up is a set of easily removeable injector connectors. Just squeeze the wire and remove. They take up a bit more space, but totally worth it. $25 shipped.
Finally a cas/tps connector in the same style as the injector connectors. Awesome for race car applications where you need to unhook them frequently. Drawback is that they are not keyed correct, so you will need to cut the key off the cas and tps. It will only go on the cas one way, anyway though. $10 shipped.
Here's a couple pictures on the car.
I also have a couple extra AEM Infinity 6/8h connectors as well $50shipped. I have gold plated pin for extra.
Lastly I also have some other misc connectors, gm fcs, 1g dsm temp sensor connectors, gm ait, 3pin delphi pressure sensor. Enquire with needs.
