initial settings for safc on hahn 20g
StarDiamond
217
Sep 30, 2003
Waterford,
I was wondering what a good initial setting would be for a hahn 20 g ,660's, 255 pump, hahn front mount kit, 3inch to the back stock 2g mass w/ apexi filter all combs in. Thanks jason
What are you using for a logging software? if you do not have one you should check out www.dsmlogger.com the best setting is diffrent for every car. its hard to tell you what the best set up is for your car. the best way is to try it out and log a couple runs then play with your settings after that. you need to be in the karmon set up with all your settings set to zero. Make a run and look at your PDA or whatever you are using and make corrections as needed.
