TerribleTSi
- 153
- 0
- Sep 20, 2007
El Paso,
Texas
So i blew the HG in my car on the freeway the other day and i was just going to throw in the cometic steel HG i had bought months ago then i started thinking. is it possible to swap to better pistons without getting the block rehoned. (i have some ross pistons 8.5). since i am taking the head off anyway i wanted to pull the oil pan as well and do ARP rod studs. or is it not a good idea to do that without getting the crank machined and block rehoned? my motor has almost 80k on it. so in a nut nutshell does anyone know if i can do rings,pistons, and rodstuds without getting the block and crank machined?
i was planning on doing this with the block and trans still in the car. i don't have a place to pull my motor out. if this is not a good idea i will just have to wait on it and just do the HG and head studs for for now.
. But it worked and it worked fine. So it is definately doable, not suggested, but doable.
