philly5eagle
- 0
- Apr 5, 2005
virginia beach,
Virginia
Idles fine without a/c on. If i turn a/c on the rpms drop to about 500. I have read about idle surge etc but I dont have that. Idle is at 750, sometimes to 800 but pretty much steady, even steady at 500 with a/c on. I cked the ohms on the isc and all read 32. I unplugged the a/c comp. to see what happens looks like the rpms drop for a second and then back to 750. Question is, does the isc move due to the load on the engine or due to an electrical signal that tells it the a/c has come on. I have looked in multiple places and heard it both ways and I'm trying to find out which is correct b/c that may help narrow down the problem. If my compressor is bad then may be putting too much of a load on the engine. Or maybe something else. I must mention that this problem started around the same time I had a problem with the alternator . I was driving at night and the lights went dim etc. Drove it as far as I could to get it somewhere to park and the next day picked up a alt from the junkyard just to get by. Is it possible that the alt is not putting out enough or is something else fried somewhere. I read a few people having the exact same problem but never an answer to the problem. they have replaced alt, isc, ecu etc and never fixed problem.
