anconover
well if your going to run a 16g size turbo, no need to worry about having top end
Stock intake manifold is perfect, dont touch it. Pulls to 6k'ish, and outperforms most manifolds low/mid range. Put a 16g on the car, with injectors, and just leave it.
uts flamesuit on:: Would be a 2.3-2.4l stroker 8.5 compression, 2g head stock, 2g im stock, 1mm oversized valves, 1g tb, 264/264 cams, 18 psi on a ported t28 killer, small-decent size FMIC(good enough to cool the flow of 550cfms, i.e dejon tool street FMIC), short route piping, 2.5in o2 eliminator turbo back WITH 2.5in catalytic converter...muffler optional, 550cc, 190l, safc or dsmlink. I would say that combo would put everybit of 320-350hp to the wheels, as well as but loads of torque...Im guessing over 400.
A t25 has NO top end... Also an NA v8 ( assuming it's an ls1 or one worth modding ) will pull on a properly supported 16g'd car with just an intake and a decent driver.... You ever wonder why our cars run 13.5 @ 98 ish and a TA runs a 13.5 @ 105 or more?
