i have no clue about the cps
newtypeeclipse
42
Sep 12, 2008
anchorage, Alaska
ok here is the problem, i had the car running and it all of a sudden stopped running, now the car will crank but wont start, the fuel pump turns on, i believe it is getting fuel into the motor, i checked the asd relay and it comes on when you turn the key to start the car, but there is not spark, so i replaced the coil and still no spark. i checked the the three wires going to the plug on the coil, and none of them have power, so i know its not the coil, so is it the asd relay, or the crankshaft position sensor, what is it???????
When the CPS went out on my motor (2g 7bolt) I lost fuel and not spark. the pump would come on and prime but the injectors would not fire (noid light test) I would still get spark.
