i cant find the hook up for this line
95 tsi awd
131
Oct 14, 2005
belleville, New Jersey
im putting a 14b on my 1g cause i bought the car without it and now im trying to hook the turbo lines up and i dont know where the U shaped coolant line goes and the oil linie that goes up near the head. there no where for the oil line to go. please help i need to get this car running
its not there. the guy that had the car befor me said his t4 turbo only ran on water lines so i dont know maybe be took out the thing where the oil line goes too. is that possible
its a vr-4 motor. also where on the block does that u shaped turbo line go to. does anyone have any pics of where all the lines go to and a website i can get the right banjos for it
whats size do i need for the water lines and oil lines?
whats if im missing the thing where the oil line hooks up to? i think the guy took it out cause his turbo only ran on water lines.
See this bolt on the side of the cylinder head?
That's where the banjo bolt for the oil feed line goes. The banjo bolt for the head and for the turbo are the same size (MF650102). The oil feed line, if you don't have it you can get from the dealership (MD129403 or MD140394). Be sure to pick up the copper crush washers as well.
If you don't have anywhere for the U-shaped coolant line to go, that means the previous owner took out the stock water pipe and used one from a non-turbo, which doesn't have a fitting for that line. You can get that from the dealership too (MD117764).
See these two lines sticking out from under the manifold and snaking back to the thermostat? Those are the two coolant lines from the t-stat to the turbo. The rubber line is (MD140477), the metal one is (MD140476). The banjo bolts for both coolant and drain sides are (MF650114). Don't forget about the copper crush washers for those as well.
