hub removal from knuckle
crimsondragon
4,300
51
Dec 17, 2006
East Brunswick, New Jersey
I currently have disassembled my entire front driver's side suspension. I need to get the hub out of the knuckle so I can have it milled. Currently the way it sits, hub is stuck. The 4 bolts have been removed. I want to preserve it so I can use it again. So far I have tried hammering it and slamming it down on an old turbo (the only thing that was close to circular and high enough without hitting the knuckle). No avail. Any ideas?
a large press at a local machine shop should do the trick if you can't get it any other way...
