how to tell eprom?
Also while you have the ECU out and the cover off you may want to take a look at your Capacitors to see if they are leaking. If they are leaking get them replaced and even if they're not it's still a good idea to replace them before they begin to leak. I just lost an ECU due to leaky caps.
http://www.tmo.com/howto/ecu1g/caps.htm
Has information on the Capacitors. I'm sure any electronics shop will replace them for you.
Just thought I would throw this in because leaky caps suck :barf:
