How to remove power steering pump from a 1g
Its simple you need a 3/8's ratchet , and a 14mm socket the short one. On the side with the belt if you look at the wheel it has holes in it you need to line those up with the bolts under there that hold the pump on the other side is only one bolt. Are you removing it all together? I'd shield the alternator with something before starting to remove that top nut as the oil will definitely ruin your alternator.
