how to measure / confirm normal power drain?
1Gina2G
810
May 6, 2011
Beaufort, South Carolina
okay so I'm going through a bad battery issue it seems, working on finding a good optima battery. anyways, I got a new test light that works, connected the clip to the negative post with the positive still atached, and I get the tiniest, dim light , on any of the ground cables, it's next to no light, so I'd like to assume this is the normal power drain.
Is there a way to measure / confirm normal power draw? With volts, i get 12volts no matter what it seems when i measure for voltage the same way I used the test light, probing between negative post and ground wires.
anyone set on any specific battery brands by chance? I'd like to get a known quality battery haha.
thanks everyone! :thumb:
The red top Optima battery is pretty good
But I have the red dura last on mine and Ive left the system on for 4 hours and it hasn't died
Had that battery fro a year tho ha
